33.1 C
Delhi
Wednesday, June 4, 2025
HomeHealth & FitnessNeed Relaxing Sesh At Home? Try 7 DIY Spa Recipes And Pamper...
Need Relaxing Sesh At Home? Try 7 DIY Spa Recipes And Pamper Yourself!
Due to Covid- 19 lockdown, everyone is locked at home and is busy with work, kids, chores, and many other activities. Finding time for yourself is important and challenging too. Self-care is important, and taking some time for wellness is necessary. For relaxation taking a spa at home is the best way as there is no need to leave home. DIY spa recipes are natural and cheap and best as compared to expensive beauty treatments at the salon. The best way is to put on relaxing music and start with your session to pamper yourself. These are 7 DIY Spa recipes to try for you at home.
1. Olive Oil Lip Scrub
Your lips and your smile is the most attractive part on your face. So it is important to keep your lips smooth, and pampering them is very important. There are many DIY recipes to take care of your lips, especially if they are dry or chapped. You should try out the olive oil and sugar lip scrub to make your lips smooth and attractive. To prepare this DIY recipe,
  • Take a small bowl and mix together a teaspoon of white or brown sugar with olive oil till the granules melt.
  • After that rub, that mixture on your lips for few seconds as the kit will help you get rid of dead skin.
  • Then rinse with warm water and put some natural lip balm to moisturize them.
  • You can use this DIY olive oil lip scrub twice a week for better results.
2. Papaya and Honey Face Mask
Papaya is a magical fruit for the skin as it is fully packed with Vitamin A and C. the enzyme present in the fruit is beneficial for the skin and helps to fade dark spots, blemishes and cure skin impurities; on the other hand, honey has hydrating properties that help to make skin soft, supple and smooth. To prepare this DIY spa recipe at home:
  • Take few papaya pieces in a bowl and mash them properly.
  • Mix a sufficient amount of honey so that you can make a paste of it.
  • Apply this mixture to your face and keep it for 15 to 20 minutes.
  • After that, wash your face gently, and you will feel a glow on your face.
  • This mask is best for dry skin; thus, it will be moisturized after this DIY.
3. Banana, Honey & Coconut Oil Hair Mask
Banana, coconut oil, and honey work wonder for dry hair. Bananas are rich in potassium, vitamins, and magnesium and help nourish your hair. For dry and damaged here, banana, honey, and coconut oil hair mask is best to make them silky. Mixing the honey in it will help cleanse your scalp naturally and also helps to soothe dry skin. To get smooth, silky hair at home.
  • In a bowl, makes a mixture of mashed banana, coconut oil, and honey.
  • Blend them perfectly and make a thick paste.
  • Apply it on roots to tips; after that, wash it with your regular shampoo.
Also Read: https://jjl.dcf.temporary.site/planning-for-amazing-road-trips-from-delhi-try-out-10-exciting-weekend-road-trips/
4. Ubtan Body Scrub
Applying the ubtan body scrub is the perfect way to pamper yourself and is considered one of the best DIY spa recipes you should try at home. To prepare this body scrub,
  • You have to mix some besan, atta, Sarson ka tel, a pinch of turmeric, and milk.
  • Mix all of them well till it becomes a smooth paste.
  • Apply DIY ubtan body scrub all over your body and wash when dried fully. For better results, you can apply this scrub twice a week.
  • Applying this body scrub will help you remove tan, help in hydrating skin, and keep dryness.
5. Epsom Salt Foot Soak
Epsom salt foot soaks DIY is one of the best techniques to relax yourself. Soaking your feet in the mixture helps your skin to allow magnesium to penetrate. Epsom salt helps to soothe aching joints, also help in relieving skin conditions and offer restfulness not only to the foot but also to the body.
  • Try Epsom salt foot soak DIY by taking a small tub, filling it with hot water, and mixing few tablespoons of Epsom salt.
  • You can also add few slices of lemon. After that, dip your feet in the mixture and sit back to enjoy and to relax.
6. Yoghurt & Turmeric Face Mask
Yoghurt & Turmeric Face Mask is one of the best DIY spa recipes you should try at home. The two ingredients work wonders on your skin. Turmeric is an anti-inflammatory ingredient that helps to brighten skin, and a mix of yoghurt will offer anti-acne benefits, too, as it has probiotics.
  • To prepare this face mask, you should mix yogurt and a pinch of turmeric in a bowl.
  • Apply it to your face and neck for about 15 minutes.
  • Wash your face, and you will get clear and brighter skin at home.
7. Oatmeal Body Scrub
Oatmeal is one of the best skin ingredients and should be used in DIY to pamper your skin. It has inflammatory and antioxidant properties that help removal of dead skin cells and treat dry skin effectively. Using oatmeal body scrub will keep your skin glowing and will exfoliate your body and offer amazing benefits.
  • To prepare this amazing body scrub, blend the oatmeal till it become powder
  • Mix some yoghurt along with honey in it.
  • Then, start scrubbing it on your body with soft hands and wash thoroughly.
Give an hour to yourself for a mini pampering session by trying the above listed 7 DIY Spa recipes. This spa session at home will help you to feel relaxed and refreshed.
RELATED ARTICLES
- Advertisment -spot_img
Most Popular
Recent Comments
